Hi Michael,
took a bit longer to find the time but just deleted the 2.10 version and downloaded and opened 2.11.0.4327 and, in combination with the earlier installed Formit, this seems to do the trick. Managed to quickly run through section 2.4 of the Primer up to 'adding complexity, without errors and with the desired output appearing. Now back to IT.
Thank you and Sol for your time and might I suggest version 2.10 should not be the default download at the moment?
Should there be any other issue, given that 2.11 is a pre-release, I’ll be back.
Regards,
Jeroen
