Hi, is there a way to match a family parameter to a type parameter to link on a quantitity
so if i change it shape, i apply the routine to update the wood quantity of a concrete beam
I don’t really understand your question (you’re talking about the calculation mode: Auto Shortest Longest or Product) or the management of list levels with Chevrons (>)
edit : @L2 and longest
cordially
christian.stan
how do i set up for calculation mode to longest, i managem to set up to L2 but maybe this longest is not set up
oo now it worked, thank you very much! i had troubles with the translation because in my portuguese dynamo the lacing name its truss, not lacing, thanks for the help!
Without wanting to pass judgment
, you have to do this dynamoprimer, it helps you enormously later (it’s also very good)
cordially
christian.stan
i will look for, thanks for the tip! dynamo its helping so much on the workflow, we are migrating TQS-REVIT to detail structure elements
you could change the country too ![]()
cordially
christian.stan
