Hello All,
I have a small question regarding Dynamo. I have reached to a group of polygons that connect different points in a plan and I want to filter these polygons which are parallel to the X and Y plan and I can’t do that. I have tried parallel to vector to vector and I didn’t get the right answer. Can someone provide any help ?
Thank you.
Try this:
For a Vector by the startpoint and endpoints which you gathered.
Use a Vector.AngleAboutAxis to get the angle from the X axis to each line’s direction about the Z axis.
Use a modulo node (%) to get the remaining value of you were to divide by 90.
Test the results for equal to (==) 0.
Use a ‘List.Contains’ node to find any sublists which contain a True value.
Use that resulting list to filter out your original polygons.
