Dears I’m trying to edit the code by LinkDWG to take polygons from the dynamo and export it to AutoCAD as a polyline but I keep getting Value does not fall within the expected range.
Any suggestions…
Home.dyn (9.2 KB)Dears I’m trying to edit the code by LinkDWG to take polygons from the dynamo and export it to AutoCAD as a polyline but I keep getting Value does not fall within the expected range.
Any suggestions…
Home.dyn (9.2 KB)Hello @gabdelmo
here is the corrected python code
the argument of AddPolyline function must be a Array not a list of multiple Array (note the extend function instead of append)
https://help.autodesk.com/view/OARX/2018/ENU/?guid=GUID-ED02917C-D1D6-46B8-95C6-736163C31362
# Enable Python support and load DesignScript library
from math import *
import System
from System import Array
#rtn = None
MyVar = IN[1]
rtn = None
# Place your code below this line
def _VLOPoint(pt):
return Array[float]([pt.X, pt.Y, pt.Z])
def _Core(abc):
if isinstance(abc, Polygon):
MyList = []
for i in abc.Points:
MyList.extend([i.X, i.Y, i.Z])
lstvertex = Array[float](MyList)
poly = SPACE.AddPolyline(lstvertex)
poly.Closed = True
return poly
if IN[0] == True:
try:
CAD = System.Runtime.InteropServices.Marshal.GetActiveObject("Autocad.Application").ActiveDocument
if CAD.ActiveSpace == 1:
SPACE = CAD.ModelSpace
SPACE = CAD.PaperSpace
rtn = _Core(MyVar)
except Exception, e:
rtn = e
OUT = rtn
Thanks, I really appreciate it
