Is this the same for everyone?
It seems that only the English version can be opened.
So this doesn’t work…
Google -> Dynamo Primer, first result
http://primer.dynamobim.org/en/
but this does…
Google -> Dynamo Primer 1.3, first result
http://dynamoprimer.com/en/
from here… if you change the language, it goes here…
http://primer.dynamobim.org/de
and fails.
http://primer.dynamobim.com/de also fails
The org is perhaps being updated to com and hasn’t been done everywhere yet?
Edit: see below for updates
We are making some updates to the primer. We are aware of the issues and trying to resolve them. More soon.
So, I just checked and it appears like everything is working. Please clear your browser cache and try again.
Hi Racel,
I told Chrome to clear my cache and hit the links again, they are all responding as before.
I presume you’re saying that if I go to the http://dynamoprimer.com/en/ and change language it should open the German version? I’m afraid that is still failing for me.
Cheers,
Mark
I made a few more changes to the DNS. Can you please clear your cache and try again?
It may just take some time for the DNS to update. I suggest that you check again later and let me know. Some times it can take up to 24 hours to update.
@Mark.Ackerley try this link: http://dynamoprimer.com/de/
That link now works
Make sure you’ve cleared your cache and that you don’t have a firewall blocking access. DNS may still be taking some time to update to your location. I just checked and each link is working correctly on two devices on separate networks.
@Mark.Ackerley
as you can see the German version is hosted on the .org domain
Edit: I cleared my cache and the com.de and org.de both work for me, the primer takes me to the org.de
I tried both .com and .org failed
Can work. Thank you
Hi all- The DNS looks like it finally updated. Please check again and let me know. If everything looks to be in order, please mark this as resolved.
