Dynamo player-Multiple selections input optional?
Hi all, i am trying to make Multiple selections input optional on the dynamo player i tried to add IF node with Boolean but it did not achive the purpose i still have to make a selection or the script won’t run , and if there is a possibility to make checklist inputs on the dynamo player, i only found data-shap package but I wonder if it is feasible by the default player
Thank you
Data-Shapes typically allows you to provide a default value.
Yes like Sean said, it is possible through the Data-Shapes package, what you want is not possible through the standard Dynamo Player.
Thank you Sean for the help
thank you daan, yes i will try it
