Hello people,
I was working on the dynamo to create a parametric window with mullion. (Something like ones from Esherick House)
I think I got the geometry in either surface or curve of window frame in the file that I attached.
However, I don’t know how I can translate these geometries into mullion or other elements so that I can insert them to my revit file.
Please let me know.
Thank you very much!
jylee89
You are using nodes that query curtain walls for mullions and panels. What you’ll want to do is create your panels and mullions as adaptive components / pattern based CW panels and them place them using one of the Adaptive Component nodes. If you do a search for “panel” or “adaptive” on the forum, you should eventually find a thread that describes the process. Also, have a look at the Revit samples that ship with Dynamo.
