First I made mass from dynamo
Second I want to modify dynamo mass into wall by using wall by face
What should I do?
What should I do?
There is no Wall By Face option
See if you can instead select/specify the base curve of the wall and use Wall.ByCurveAndHeight or Wall.ByCurveAndLevels
There is a custom node from “Clockwork Package” called “Wall.ByFace”. You can use that node to create wall by face.
I stand corrected, apparently there is a node, just not OOTB
Would you make sample script using Wall.ByFace. Please
Sure give me your mass.
Hello everyone, I tried to create my WallByFace and it works, but I can’t understand why I can change the wall type only 1 time. For example, I set to “Generic150” and I see in my Revit document the wright changes, but if I return in Dynamo and re-change to “Generic 300” it doesen’t work, the node give me “Empty List” and the transformed surface remains a “Generic150”, both in automatic and manual run mode. Thanks
Hi @Riccardo_Marchi,
Can you show us screenshot of your work so far. It would be better if you can start a new topic and link this post as a reference link. Thanks
Can you Upload the mass so we can examine it in detail?
Mass Group and IFC file
Hi this is the behaviour I’ve noticed when the surface is cut. The wall is created following the original uncut surface.
So far I haven’t found a direct solution.
Workarounds I’ve used are rebuilding the surface without cuts and cutting the wall once created with a void family. Or using an in-place wall.
I hope this will be resolved in future versions of revit.
hey guys im new here for dynamo if i have created a mass in fusion and then imported it revit by dynamo im facing some problems when i try to create wall by mass. what should be done in this situation
Translated by moderator. Original post below the line.
Good afternoon.
The node only works on a mass surface … on columns - does it work on any surface?
Original post below.
Buenas tardes.
El nodo solo funciona en una superficie de massa …¿sobre columnas - funcione sobre cualquier superficie?
hello @AM3D and welcome to the forum! The official language here is English, which is a requirement to make search work. Please translate future posts as I did in the edit of your post above. Thanks!
ok
Hi with all ,
Is there a way to create (wall by face) from columns or walls?
or in any case, is there a way to convert objects into masses so that it works, what I want to do is take elements and get finished walls?
