Dynamo losing some data when used If Function
Hello, I try to used dynamo and I have a issue with IF function. What wrong with this.
Thank a lot.
@yukuyukumi2 The OOTB node doesn’t work with lists of different length.
Try one of the following nodes:
Thanks a lot for your suggestion. It’s very helpful.
@yukuyukumi2 Not a Problem. Please mark as solved
@yukuyukumi2 Don’t mark mine as the solution (mark Salv’s) - but Zebra also comes with a node (Logic.If) as well which still works in 2.x.x versions.
You didn’t post here :smile:
