Dynamo inside Formit v17. FormIt.BakeToFormit node dosent work
Hi, Autodesk recently added Dynamo inside formit with new node FormIt.BakeToFormit, with should transfer dynamo geometry into formit. I can’t make it work, it’s not working for me or I just use it the wrong way?
Edit. ok i get it now, its just still as it was, you have to load script into formit dynamo player.
We’re unable to make the original post the solution so I’m gonna use my quote of your edit instead. Glad you’re sorted out though. :slight_smile:
