I was using a scrip for wall disallow join and as well as beam disallow join. That was working properly on a normal basis.
But while I am working inside a model group in edit group mode in that case my dynamo scrip getting stucked and not working properly.
Is there any remidy for that?
Unfortunately not. You’re inside a transaction when modifying the group. You can’t open a new transaction with Dynamo while there’s one still running in Revit.
In theory, you could use Dynamo to ungroup the elements, make the change, and then regroup, but this would create a new group type and not maintain like groups without deleting all groups of the original type and replacing them with the new, fixed group.
That’s the major problem while working in a wide range of projects where we work with model groups for the typical levels.
Anyways, thanks for your kind response.
