Dynamo - how to break connection with rvt
is there a way to “break” connection or refresh it after my script has run its course?
The issue is that I want to create in a single revit file multiple steel towers one after another, but after selecting different input data (location, height, profiles etc) the previous one gets erased from project… Screenshot below:
Dynamo graph:
_test.dyn (259.0 KB)
@rafal.actun
Take a look on this one here it could probably help you…or try to execute from the player…
Hey, thanks for quick reply, it seems more complicated than I thought. Basically it comes down to manually creating many dyn files on the fly and disconnecting/reconnection nodes manually to get rid of the “bindings”…
If there is any other solution to this problem I’d be grateful for any input :wink:
You could try to execute from the player…or think @john_pierson had a node there can “Bake element”
or you could try to write your script in python…there you had the option to do so…
Oh that’s prefect! Works like it’s supposed to. Had a hunch that someone already created a custom node for this :sunny:
Great :wink:
