I am new in to Dynamo and I am currently trying to create a grid that has set dimensions (I understand that you can’t give dimensions but I am using revit and want to put the grid to the ceiling). I am currently using a code block to define the start stop and range points, however, instead of the range being how many points appear I want the range to be the distance or even scale between the points but I don’t know if this is possible? Can you please tell me if it is possible and how I can approach this? Thank you
Thank you so much! That helps heaps
