Can anyone please help me to make points I created in Dynamo to be communicated to C3D’s Model Space?
I do not want COGO Points, but “simple” points (i.e., x=10, y=20, z-10).
Many thanks!
Many thanks!
Hi @alexmotta19,
Look in the Civil 3D Toolkit package for a shelf called “DBPoint”. That should have the nodes you need.
It worked, @mzjensen, thank you very much!
However… my input file is a list of points with “name”, X, Y and Z.
Some of these have Z=0 and I would like to create a second list with the points that have Z different than 0.
From this second list, I will creat “ghost points” with Z=0 so that I can build lines connecting the “real” with the “ghost” points (I do hope it makes sense).
May I ask how I can produce this second list, please, remembering that it has 4 columns and a “variable” number of rows?
Thank you very much in anticipation!
Alex. Can you share your data set so i can understand better what you’re referring to?
Yes, of course! Thank you in advance!
I “improved” the problem in a new post at Placing points with lables, creating duplicate points at Z=0 and connecting them with lines in C3D's Model Space - I tried to tag you there but could not… (tagging you here though, @WrightEngineering)
Many thanks in advance!
