I am trying yo create false ceiling room wise. the Problem is that calcium silicate tile are of size 600x600mm. To avoid cutting of tiles, we use gypsum border all around the room so that balance area can accurately be filled with tiles without cutting.
any general direction would be great.
Till now, i have created polycurve, now i am trying to fin distance between diametrically opposite line and offset each so that the remaining distance is multiple of 600mm. by doing this outline of gypsum border can be obtained.
is it possible to convert each segment into a vector and then get distance between pair of 180 degree opposite vectors and distance between them?
so as not to do the work for you (the direction of the forum, is a lot of direction ) here is an additional potential directions the rest I will leave to you to resolve
edit:
cordially
christian.stan
Hello @abhaycpwd9411 and welcome…is it something here you are after ? if so then sparrow have some nodes there probably could help…
I tried another way in python to train, but the packages are certainly more suitable
Python script
import sys
lines=IN[0]
vx=[Vector.ByTwoPoints(l.StartPoint,l.EndPoint) for l in lines]
vy=[Vector.Cross(v,Vector.ByCoordinates(0,0,-1)) for v in vx]
cs=[CoordinateSystem.ByOriginVectors(l.StartPoint,vxi,vyi) for l,vxi,vyi in zip(lines,vx,vy)]
long=[l.Length for l in lines]
dxx=[(l-(l//0.6)*0.6)/2 for l in long]
dyx=dxx[::-1]
pts=[Point.ByCartesianCoordinates(c,dx,dy) for c,dx,dy in zip(cs,dxx,dyx)]
poly=PolyCurve.ByPoints(pts,True)
OUT = poly
Sincerely
christian.stan
