Dynamo for Civil 3D 2025.2 Release
it’s annoying that the new version doesn’t provide backward compatibility. I have scripts created based on Civil3DToolkit. The nodes I used are no longer available, and no replacement is provided, for example DocumentExtension.GetDocumentStyles. I used it to create custom lists with the Data-Shapes package because the built-in lists are insufficient. I think Dynamo from Civil 2025.2 is a change for the worse, and I don’t understand why there is no backward compatibility provided. Now I have to change all the scripts I created, which is frustrating.
There was a post about this package a while ago, there may be OOTB nodes that could easily be replaced.
Future of Civil 3D Toolkit and Camber Packages - Civil 3D - Dynamo
A post was split to a new topic: Pick Point node values seem incorrect
Did you ever find a replacement for the missing DocumentExtension.GetDocumentStyles node?
I created a Python script with ChatGPT’s help
import sys
# referencje Civil 3D API
clr.AddReference("AcMgd")
clr.AddReference("AcDbMgd")
clr.AddReference("AeccDbMgd")
from Autodesk.AutoCAD.ApplicationServices import Application
from Autodesk.AutoCAD.DatabaseServices import OpenMode
from Autodesk.Civil.ApplicationServices import CivilApplication
# === PARAMETR WEJŚCIOWY ===
# przykład w Dynamo: IN[0] = "CorridorStyles"
styleType = IN[0]
# aktywny dokument
doc = Application.DocumentManager.MdiActiveDocument
db = doc.Database
civilDoc = CivilApplication.ActiveDocument
style_names = []
error_msg = None
tr = db.TransactionManager.StartTransaction()
try:
    # pobranie głównego obiektu StylesRoot
    stylesRoot = civilDoc.Styles
    # obsługa zagnieżdżonych właściwości, np. LabelSetStyles.AlignmentLabelSetStyles
    parts = styleType.split(".")
    current = stylesRoot
    for p in parts:
        if hasattr(current, p):
            current = getattr(current, p)
            error_msg = "Nie znaleziono właściwości: " + p
            current = None
            break
    if current is not None:
        # jeśli kolekcja ma StyleId (ObjectIdCollection), iteruj
        try:
            for styleId in current:
                style_obj = tr.GetObject(styleId, OpenMode.ForRead)
                try:
                    name = style_obj.AcadObject.Name
                except Exception:
                    try:
                        name = style_obj.Name
                    except Exception:
                        name = str(style_obj)
                style_names.append(name)
        except Exception as e_iter:
            error_msg = "Błąd iteracji kolekcji: " + str(e_iter)
    tr.Commit()
finally:
    tr.Dispose()
# wynik
if error_msg:
    OUT = "⚠️ " + error_msg
    OUT = style_names
Thank you for sharing this code. I’d like to know what prompt you used for ChatGPT. Also, do you know how to apply the band set styles to the profiles after retrieving the style names?
