The button on the addin tab in Advance Steel doesn’t start dynamo. This is confusing because a few days ago it worked fine. I’m on Advance Steel 2017.1 and the Dynamo extension came with it.
It could be because I downloaded Dynamo 1.2.0, but I’m only guessing…
Yes it might be. I would suggest you uninstall completely all the previous packages and try installing latest Dynamo v1.2 and restart you PC. see if that helps!
I forgot to mention that when I tried to repair Dynamo Extension via Control Panel the message was displayed.
Should I remove the Dynamo Core and the Dynamo Extension as well?
If all that fails. The software is also available to install using a GitHub repository which contains the source files of DynamoAdvanceSteel addin, that connects Dynamo with Advance Steel. Click Here for Files.
A while ago I dl-ed the files, did some unsuccessful thinking on how to get things started, and when the 2017.1 got out the issue was gone, and Dynamo was running.
Looks like reinstall of AS could be the fastest solution.
Hello Guys !!!
I’m study user, i’m learning advance steel and Dynamo, But i can’t see a update extension Dynamo for Advance steel. Can you upload extension Dynamo for Advance steel for me ?
Please help me !
Thank you so much !!!
