Dynamo-Feature Line-Manipulate features lines
Hello All,
I was wondering if you can still manipulate feature lines even if you select the feature line “OBJECT” by “LAYER” and not by site?
Yes, you can use the FeatureLine.ByObject node from the Civil 3D Toolkit and then whatever you need from there.
How do you change the elevation of a feature line? Would I need to convert the feature line to a dynamo line, then use the getZelevation? I tried using the feature line PI elevation node; however, it gives a null.
