Greeting,
I tried to open Dynamo in Revit today. unfortunately, it doesn’t work today. I have check the dynamo window, but it doesn’t show up.
Has anyone met the same problem? Thank you for your help!
Likely it opened on a portion of a monitor which no longer exists as you have a new configuration or resolution.
Hit alt + tab to find Dynamo in the list. Then hit alt space bar m, which will start the move window command. Then hit left arrow key and then move your mouse.
Update - For us if we disabled the AVAIL for Revit addin, Dynamo would launch. Thankfully 2026 added the nice Addin Manager that made that easy to do.
You have an add-in or other tool which is in conflict with Dynamo. Disable all your Revit add-ins and Dynamo packages to identify if this fixes the issue. Once done enable them in small groups until you find the conflict.
Once identified, updating the add-in to the latest version will usually resolve the issue, and if not let the add-in provider know so they can update on their end.
It was AVAIL - I have contacted them to let them know and hopeful find a solution.
Thank you for your advice. I have tried, unfortunately, it seems like it isn’t the cause.
Wonderful. Thank you so much. Yes, it works. You saved my life:)
