Hi, I installed Dynamo 2015 for computational design practice but i cant see it on Revit 2015 addins tab…where as when i installed Navis works manage it automatically appeared in the addins tab. Please help. i tired re installing, it did not work. thanks.
Hello BEENISH NOOR,
Can you check whether Addin file generated at following location for Revit 2015?
C:\ProgramData\Autodesk\Revit\Addins\2015\Dynamo.addin
If it is there, then check if it is pointing to correct location.
<Assembly>“C:\Program Files\Dynamo 0.9\Revit_2015\DynamoRevitVersionSelector.dll”</Assembly>
Thanks,
Ritesh
Thanks Ritesh, No i dont have the Addin file on that location. how can i fix it?
