Hello #DynamoBIM fam!!
Hot off the press - We’re super excited to announce the release of Dynamo 3.6, and trust us, it’s packed with some amazing updates and performance boost that you won’t want to miss!
Check out a quick blurb below:
This release introduces a revamped and more discoverable Node Autocomplete experience, enhancements to groups, and bug fixes. In addition, it adds significant performance updates that are all about turbocharging your Dynamo navigation experience, making it faster and more responsive, thus minimizing your wait time.
Learn more about the release in our blog: Dynamo Core 3.6 Release - Dynamo BIM. For full details, check out the release notes.
When you’re ready to explore, you can download the release here.
We can’t wait for you to test out Dynamo 3.6—your feedback means the world to us!
Don’t forget to share your feedback in the comments below!
Previous few release blog posts:
Dynamo Core 3.5 Release - Dynamo BIM
Dynamo Core 3.4 Release - Dynamo BIM
Dynamo Core 3.3 Release - Dynamo BIM
Translated by moderator. See below the line for original post.
When I run the node after installation, the error “Could not load file or assembly ‘C:\Programs\Dynamo\LibG.ProtoInterface.dll’. The system cannot find the file specified.” pops up.
Original post below.
我安装后运行节点时弹出“Could not load file or assembly ‘C:\程序\Dynamo\LibG.ProtoInterface.dll’. 系统找不到指定的文件。”这个错误
You may need to install a newer build of a core Autodesk product, such as Revit, AutoCAD, Alias, etc..
Does the Sandbox version require the installation of core Autodesk products?
Sandbox版需要安装核心Autodesk产品吗
Hey @732176326 the official forum language is English, which is a requirement to make search work (annars skulle jag bara posta på svenska för at öva). Please translate all posts going forward as I did int he edits to your last two posts, keeping your native language post on one side of a separator if desired (it may help should we get multi-language support one day).
To use the geometry library in Dynamo you need to have a core Autodesk product (with a valid license) installed on the system.
