Dynamo code block function return strange things
Hi, I’m currently progress in auto rebar modeling using dynamo for my project.
Cause of some reason I use pre-defined code block function for return stirrup rule by column type.
I was intend to get
[-480,-780,-1080,-1380,-1680,-1980,-2280,-2580] for type 1
and
[-480,-780,-1080,-1380,-1680,-1980,-2280,-2580, -2880, -3180, -3480, -3780, -4080, -4380] for type 6
But what I get after run dynamo is
and
[-480,-780,-1080,-1380,-1680,-1980,-2280,-2580] for type 6 ( Can notice that number of data is 16, if it return properly it would be 22)
I already check argument for call function (type 1 and type 6 are used).
How can I get correct return from code block function?
You will need to define an Imperative Function
def stirrupRules(type)
    return [Imperative]
	    if (type == 1)
	    	return [-480,-780,-1080,-1380,-1680,-1980,-2280,-2580];
	    elseif (type == 6)
	        return [-480,-780,-1080,-1380,-1680,-1980,-2280,-2580, -2880, -3180, -3480, -3780, -4080, -4380];
	    else
	    	return [-480,-780,-1080,-1380,-1680];
Thanks @Vikram_Subbaiah :).
Now it work Correctly.
Seems like you’re trying to build a dictionary? Just for reference you could do it with OOTB nodes as well :slight_smile:
What i want to do was “Give column type (from A to F) to function and get each types stirrup height” I solve those problem via vikram thanks for your interest.
Happy new year!
