i knew it should not be that easy! You already manually associated the “MATERIAL” parameter to the “Extrusion Material” (let call this TEST MATERIAL- extrusion material is confusing term) already LOL.
Case study here is : What if family was created from solid in dynamo → no family file rfa saved
Yes, 1st way to work around it is to save the family to a directory on the PC and associate the parameter manually, but what if we have 2000 families created with Dynamo, do we have to go in each one of them and associate the parameters to each other? → huge load of work.
2nd way is mentioned in the topic below by Erfajo. Batch Save the family to .rfa file in PC → open these files in background to assigned parameter → and then associate parameters with his dynamo graph. Thanks Erfajo, this is great workflow, I find it is genius. But still too much work to do, and we still need physical RFA files.
What I am looking for is what if we can do it all in Revit project environment with Dynamo ??? Can Dynamo really do this?
Somehow we can use Dynamo to access the family Extrusion element to get the extrusion “MATERIAL” Parameter, then associate this MATERIAL parameter to the “TEST MATERIAL” without the .rfa file, without opening the family editor foreground or background, and this is quite a challenge, I have not seen anyone mentions this in the forum since last topic of Erfajo. (attached below)
Refer this topic to my newer post. Please have a look and make comment if you have a solution. Thank so much for replying @_Vijay
