Dynamo 2.18 (Revit 2024.1 )- Bar Chart Not Displaying
I am trying to get any of the Chart Nodes to display in graph, but without success.
But lets look at the Bar Chart node as an example. (Graph attached) Trying to emulate results shown on Dynamo 2.18 new features page, ie create a simple chart with some names, numbers and some colour assignments.
No errors result on Bar Chart node. But looking at Watch node I would expect the color reference to feature. A couple of questions as it is not too clear on the help.
  1. Should the Chart display once run?
  2. I am missing something in this script? Possible, it is getting late for me here in UK!
  3. Have tried other Chart nodes (none of them preview graphics, although watch nodes seem to show values!
Hoping some kind soul will put me back on the right path!
Can you restart the CPU, launch Revit and then Dynamo, open this graph, see the reproduced error, and then quit Revit and post your Dynamo log file and Revit journal? Might be something in there around a dependency conflict.
Rebooted, restarted revit, started with a blank document.
No errors witnessed just doesn’t display the bar chart as I would expect and as documentation suggests.
Wont let me send attachments in reply will try and add to original message.
Thanks again for reply!
Still wont let me attach files… Dynamo log below.
Dynamo log started 2023-07-19 18:52:05Z
2023-07-19 18:52:06Z : Python template set to default.
2023-07-19 18:52:07Z : launch darkly initalized
2023-07-19 18:52:07Z : LD startup time: 675
2023-07-19 18:52:07Z : <<<<>>>>
2023-07-19 18:52:07Z : feature flag exe starting
2023-07-19 18:52:07Z : {“graphics-primitive-instancing”:false,“testFlag”:false,“EasterEggIcon1”:false,“EasterEggMessage1”:“NA”,“CER”:false,“NodeAutocompleteMachineLearningIsBeta”:true,“CER_v2”:true}
2023-07-19 18:52:07Z : EasterEggIcon1 is false FROM MODEL
2023-07-19 18:52:07Z : EasterEggMessage1 is disabled FROM MODEL
2023-07-19 18:52:08Z : Dynamo – Build 2.18.1.5096
2023-07-19 18:52:09Z : System.InvalidOperationException:
2023-07-19 18:52:09Z : There already exists an AlsoKnownAs mapping for DSCoreNodesUI.Logic.If.
2023-07-19 18:52:09Z : There already exists an AlsoKnownAs mapping for If.
2023-07-19 18:52:09Z : Duplicate migration type registered for SunPathDirection
2023-07-19 18:52:10Z : AnalyticalAutomation.dll,M:AnalyticalAutomation.AnalyticalElements.AnalyticalPanel.BySurface(Autodesk.DesignScript.Geometry.Surface,System.Boolean) {0} is missing some XML documentation tags.
2023-07-19 18:52:10Z : The folder ‘C:\Program Files\Autodesk\Revit 2024\AddIns\DynamoForRevit\Built-In Packages\Packages’ does not exist
2023-07-19 18:52:11Z : Dynamo will use the package manager server at : https://www.dynamopackages.com
2023-07-19 18:52:11Z : The folder ‘C:\Program Files\Autodesk\Revit 2024\AddIns\DynamoForRevit\Built-In Packages\Packages’ does not exist
2023-07-19 18:52:11Z : A package called DynamoPlayerExtension found at C:\ProgramData\Autodesk\RVT 2024\Dynamo\2.18\packages\DynamoPlayerExtension includes dll files but none are defined in node libraries in the package manifest. Ignoring it.
2023-07-19 18:52:11Z : The folder ‘C:\ProgramData\Autodesk\RVT 2024\Dynamo\2.18\packages\DynamoPlayerExtension\dyf’ does not exist
2023-07-19 18:52:11Z : Dynamo Player Extension (id: 3CD8E967-22D5-46C7-8E08-316BC53AEA1D) extension is added
2023-07-19 18:52:11Z : The folder ‘C:\ProgramData\Autodesk\RVT 2024\Dynamo\2.18\packages\GenerativeDesign\dyf’ does not exist
2023-07-19 18:52:11Z : The folder ‘C:\ProgramData\Autodesk\RVT 2024\Dynamo\2.18\packages\GenerativeDesign.Extension\dyf’ does not exist
2023-07-19 18:52:11Z : Generative Design (id: DFBD9CC0-DB40-457A-939E-8C8555555A9D) extension is added
2023-07-19 18:52:11Z : The folder ‘C:\ProgramData\Autodesk\RVT 2024\Dynamo\2.18\packages\GenerativeDesign.Revit\dyf’ does not exist
2023-07-19 18:52:11Z : DynamoPackageManager (id: FCABC211-D56B-4109-AF18-F434DFE48139) extension is added
2023-07-19 18:52:11Z : Backup files timer is started with an interval of 60000 milliseconds
2023-07-19 18:52:11Z : SYSTEM:Environment Path:C:\Program Files\Autodesk\Revit 2024\AddIns\SteelConnections;C:\Program Files\Autodesk\Revit 2024\en-GB;C:\Program Files\Autodesk\Revit 2024;C:\Program Files\Common Files\Autodesk Shared\RealDWG Shared 2024;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files\Microsoft SQL Server\120\Tools\Binn;C:\Program Files\dotnet;C:\Program Files\Common Files\Autodesk Shared;C:\Program Files\Microsoft SQL Server\150\Tools\Binn;C:\Users\DennisCollin\AppData\Local\Microsoft\WindowsApps;;C:\Program Files\Autodesk\Revit 2024\AddIns\DynamoForRevit
2023-07-19 18:52:12Z : RENDER : Rendering Tier: 2
2023-07-19 18:52:12Z : RENDER : Pixel Shader 3 Supported: True
2023-07-19 18:52:12Z : RENDER : Pixel Shader 4 Supported: False
2023-07-19 18:52:12Z : RENDER : Software Effect Rendering Supported: True
2023-07-19 18:52:12Z : RENDER : Maximum hardware texture size: 16384,16384
2023-07-19 18:52:13Z : RENDER : Rendering Tier: 2
2023-07-19 18:52:13Z : RENDER : Pixel Shader 3 Supported: True
2023-07-19 18:52:13Z : RENDER : Pixel Shader 4 Supported: False
2023-07-19 18:52:13Z : RENDER : Software Effect Rendering Supported: True
2023-07-19 18:52:13Z : RENDER : Maximum hardware texture size: 16384,16384
2023-07-19 18:52:13Z : Documentation Browser (id: 68B45FC0-0BD1-435C-BF28-B97CB03C71C8) view extension is added
2023-07-19 18:52:13Z : DynamoManipulationExtension (id: 58B0496A-E3F8-43D9-86D2-94823D1D0F98) view extension is added
2023-07-19 18:52:13Z : Properties (id: 28992e1d-abb9-417f-8b1b-05e053bee670) view extension is added
2023-07-19 18:52:13Z : Graph Node Manager (id: F76F4274-537D-4782-B1E9-27E8FDE2186F) view extension is added
2023-07-19 18:52:13Z : LibraryUI - WebView2 (id: 8b093acd-5656-4914-b6b0-c54b26ca6d0e) view extension is added
2023-07-19 18:52:13Z : Graph Status (id: 3467481b-d20d-4918-a454-bf19fc5c25d7) view extension is added
2023-07-19 18:52:13Z : Notifications (id: ef6cd025-514f-44cd-b6b1-69d9f5cce004) view extension is added
2023-07-19 18:52:13Z : Package Details (id: C71CA1B9-BF9F-425A-A12C-53DF56770406) view extension is added
2023-07-19 18:52:13Z : Generative Design Tools (id: DFBD9CC0-DB40-457A-939E-8C8555555A9D) view extension is added
2023-07-19 18:52:13Z : PackageManagerViewExtension (id: 100f5ec3-fde7-4205-80a7-c968b3a5a27b) view extension is added
2023-07-19 18:52:13Z : Python Migration (id: 1f8146d0-58b1-4b3c-82b7-34a3fab5ac5d) view extension is added
2023-07-19 18:52:13Z : Workspace References (id: A6706BF5-11C2-458F-B7C8-B745A77EF7FD) view extension is added
2023-07-19 18:52:14Z :
Welcome to Dynamo!
2023-07-19 18:52:14Z : 00:00:01.3280128 elapsed for loading Dynamo main window.
2023-07-19 18:52:15Z : EasterEggIcon1 is false from view
2023-07-19 18:52:15Z : EasterEggMessage1 is disabled from view
2023-07-19 18:52:16Z : Browser Loaded
2023-07-19 18:52:16Z : WPF Render Mode: SoftwareOnly
2023-07-19 18:52:45Z : Active view is now Level 0
2023-07-19 18:52:46Z : Failed to apply NodeViewCustomization for PieChartNodeModel
2023-07-19 18:52:46Z : System.Windows.Markup.XamlParseException:
2023-07-19 18:52:46Z : Set property ‘Dynamo.UI.SharedResourceDictionary.Source’ threw an exception.
2023-07-19 18:52:46Z : at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at CoreNodeModelsWpf.Charts.Controls.PieChartControl…ctor(PieChartNodeModel model)
at CoreNodeModelsWpf.Charts.PieChartNodeView.CustomizeView(PieChartNodeModel model, NodeView nodeView)
at lambda_method(Closure , NodeModel , NodeView )
at Dynamo.Wpf.NodeViewCustomizationLibrary.TryApplyCustomization(NodeModel model, NodeView view, InternalNodeViewCustomization customization)
2023-07-19 18:52:46Z : Failed to apply NodeViewCustomization for BarChartNodeModel
at CoreNodeModelsWpf.Charts.Controls.BarChartControl…ctor(BarChartNodeModel model)
at CoreNodeModelsWpf.Charts.BarChartNodeView.CustomizeView(BarChartNodeModel model, NodeView nodeView)
2023-07-19 18:53:04Z : Clearing workspace…
2023-07-19 18:53:07Z : Active view is now Level 0
2023-07-19 18:53:08Z : Failed to apply NodeViewCustomization for BarChartNodeModel
2023-07-19 18:53:08Z : System.Windows.Markup.XamlParseException:
2023-07-19 18:53:08Z : Set property ‘Dynamo.UI.SharedResourceDictionary.Source’ threw an exception.
2023-07-19 18:53:08Z : at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
2023-07-19 18:53:11Z : Saving C:\Users\DennisCollin\AppData\Roaming\Dynamo\Dynamo Revit\backup\Bar chart 2nd attempt.dyn …
2023-07-19 18:53:11Z : Backup file is saved: C:\Users\DennisCollin\AppData\Roaming\Dynamo\Dynamo Revit\backup\Bar chart 2nd attempt.dyn
2023-07-19 18:53:51Z : Extension tab added to the extensions side bar.
https://cadline365-my.sharepoint.com/:t:/g/personal/dennis_collin_cadline365_onmicrosoft_com/ERK_ZLZYl2xKq6XjUzSsgfMBzX5oge_JUx8cmsfm94G36A?e=u2P0f3
See if this link for Revit Journal works all the script is just processing numbers not accessing anything in Revit document
EDIT
Also added link to my script…
https://cadline365-my.sharepoint.com/:u:/g/personal/dennis_collin_cadline365_onmicrosoft_com/EUs2A7z4dCtNj5uByietuZEBi2glvqsqnPN3bj98ByPn_A?e=Df5fKu
So we can see that there is an error with the xml parsing, but not why or what the conflict might be.
Try disabling all your Revit add-ins, and Dynamo customizations and packages and see if that clears things up.
If not, let me know hwre so I can flag development.
No joy, even uninstalled Revit 2024
Rebooted , reinstalled and reapplied 0.1 patch still no success. Dynamo still seems to have issues parsing that XML
I did also have the Enscape Add-in installed, but even after removing it and restarting Revit/Dynamo still no joy
Colleague also has the same issue, ie script doesn’t display pie or bar chart
Can you post the journal and Dynamo log from when enscape and other add-ins were disabled?Dev team will need these at a minimum. If it’s easier you can submit a ticket via the accounts portal at manage.autodesk.com.
I will attach here.
Enscape has been uninstalled for now, restarted app and system several times. Log and journals attached (think I can do that now)
journal.0042.txt (192.5 KB)
dynamoLog_9146dedf-f427-4e29-902b-034da4125e34.txt (11.2 KB)
Its a shame really wanted to have a play with these new nodes. But hopefully some solution will turn up soon. Do have older Revits 2022/23 also installed , not sure if relevant but just in case uninstalled / disabled from them too. (nothing odd just old versions of Archilabs Clockwork etc.) But these werent visible for 2024!
Appreciate responses so far.
Thanks - Dennis
Opened the DYN you attached earlier in sandbox but it worked for me. Would you do me a favor to download the released Dynamo 2.18 sandbox and give it a try? I will also ask the dev team tomorrow if they have any idea about this, but would appreciate if you could try that without the Revit host to give us more information.
Thanks,
Dynamo Team
OK Will do.
Thanks for confirming my script runs ok, downloading Dynamo Sandbox now.
If that works ok, will try Dynamo with Formit (if it contains Dynamo 2.18)
EDIT
Just realised FORMIT only has Dynamo 2.17, but I’ll tinker with 2.18 in sandbox for now, just a pity cant do anything with charts and a Revit document yet.
Got Dynamo Sandbox working ,after I unblocked ZIP file
But as you can see all works ok might try my luck with the Dynamo with Formit, information might prove useful. Least I have something to tinker with now!
Heard back from the Revit team, this is a known issue with the Dynamo for Revit shipped with 2024.1. They think we’ll have a fix issued with 2024.1.1, for which I don’t have a date but I don’t expect it will be too far out… All of which is to say whatever you learn by playing with sandbox or FormIt will be able to be implemented in Revit soon (I think). :slight_smile:
That’s wonderful Jacob. Thanks to you and Aaron for the prompt responses
Appreciate the update, I will share that info to the wider team here. Look forward to the new fix and will test it once out! Been busy with other stuff today, AutoCAD of all things, but hopefully will get back to Dynamo proper and Revit soon!
Thanks again! :slight_smile:
I am having the same issue with Pie Chart node not being available in Dynamo for Revit 2023.1.2.
I have installed Dynamo Core 2.16.1.2727 and Dynamo Revit 2.16.1.6510
Thank you
Out of the box chart nodes are available with the Revit 2024.1 release. If you are using Revit 2023 you’ll have to use a package.
You need Dynamo 2.18 which comes with 2024.1. For 2023 I think its the Mandrill package?
Thank you @dennis.collin I see r “Archi-lab_Mandrill” package has very great charting features.
