Dynamo 2.13 package problem
I have a problem with dynamo 2.13 packages.
At first when opening dynamo, it ask me to install the package so i do.
The packages are installed in: C:\ProgramData\Autodesk\RVT 2023\Dynamo\2.13\packages
When i close dynamo and re-open the second time, i have the same packages missing. When i try to re-install the packages it gives me an error. I should go to C:\ProgramData\Autodesk\RVT 2023\Dynamo\2.13\packages delete the packages and re-install them each time.
It’s a very big problem and it’s time consuming. Can anyone help me please ?
The problem is with : Clockwork for dynamo x2, archi-lab.net, Rhythm.
Thank you in advance.
The program data location is reserved for Autodesk packages. Community packages should be loaded into app data.
