Clockwork pkg
Hi guys,
for some reason every time I open Revit the clockwork package deleted by itself and I should install it again, anybody knows why this is happen !.
thank you
Post a screenshot of your node and package paths, and a second screenshot of the contents of those directories.
As requested
Try uninstalling and reinstalling. Backup your package directory first though.
U can drop one dyf file from the clockwork package into Dynamo and it will pop up again maybe. I think there is a Problem of u have installed a old clockwork package in the Dynamo 1.2 folder. I Have deleted all my old Dynamo folders and downloaded all package again. It seems I have solved my Problem
Hi @jacob.small i tried to do as you said but still the same issue, and i added another directory please check the picture below.
the thing is when i open any revit template the package automatically deleted from both directory :confounded:
I removed all 1.2 folders but still the package deleted upon revit opining
Guys Still Need help with that anybody can help !!!
Could you share your “DynamoSettings.xml” file found in:
%appdata%\Dynamo\Dynamo Revit\1.3\
Please find the link below for the xml file
https://we.tl/lNemUvA3CM
Close Dynamo & Revit, replace the file with the below:
DynamoSettings.txt (2.9 KB)
(I had to change the extension to upload it here, be sure to rename it back to .xml)
Start up Dynamo and re-install the missing packages
Thank you so much it’s working now, can you teach me what you did ?
That’s the file that keeps track of package folders that need to be deleted under the <PackageDirectoriesToUninstall> element. I simply removed all references.
Due to the way in which c# libraries work and the way dynamo is launched, you can only delete packages with c# dlls before they’ve been loaded. As a work around, whenever you “uninstall” such a package, its path will be stored in the settings xml and the next time you’re about to start Dynamo, the package
s directory will be deleted and ideally removed from the xml file. It seems that in your case something is breaking at that point.
