I am currently experiencing an error in Dynamo for Revit 2.13.1.3887 where any node placed will not display correctly. I have tried unloading all custom node packages and the error continues.
Disable all your Revit add-ins, restart the CPU, start Revit and create a new file from no template (select none), launch Dymamo, recreate the issue, and finally post your Revit journal and the Dynamo log file.
Thank you for your response. Looks like I had an add-in that was causing this issue.
