Hi all,
I’m use Dynamo2.12 on Revit2022. But I can’t select & show nodes.
Did anyone have solution? Thanks.
Hi all,
Restart your Computer and drink a coffee.
KR
Andreas
If restarting doesn’t work you maybe have to upgrade your Revit 2022 to 2022.1.2 or later.
99% percent certainty this is a Revit add-in conflict.
Disable all add-ins to confirm, and if it is not resolved post your Dynamo log and Revit journal from a new session with no add-ins installed where you just recreated the issue and quit everything.
I find same issue like this. But I still can’t solve.
I will feedback when fix this.
Solved: My Dynamo 2.12 does not work in Revit 2022.1 - Autodesk Community - Revit Products
I find is add-in “Microdesk Accelerator” problem. Now Dynamo can work.
