Dynamo 2.0.3 is not working on Revit 2019.2
Hi all,
I installed Dynamo 2.0.3 on Revit 2019.2 and each time i try to start the dynamo it gave me the attached error message and doesn’t work.
I searched for similar problems and i found a topic (link below) talking about a problem in using the dynamo with Revit and i remove all the add-ins as per the recommendation but it is still not solving the problem.
https://forums.autodesk.com/t5/revit-architecture-forum/dynamo-core-2-0-3-dynamo-revit-2-0-3-startup…
I tried uninstall and reinstall dynamo once and then did the same for Revit but the problem still exist.
Any suggestions?
Could you please re-attach error message, we can’t see attachment.
dynamo%20error
This is the error message.
Thanks in advance :slight_smile:
