Has anyone had this issue with the graphics of Dynamo missing? I’m unsure what would cause this. Does anyone have a fix?
A in house add-in which when disabled using “Stantec Addin Manager” fixed the problem.
We’ve seen a few issues around add-ins causing this. Try starting sandbox to see if nodes are visible there. If so then disable all add-ins and see if they show up again.
Jacob,
Thanks I just started to have a small panic attack knowing I need to generate something. thank you for the quick response.
If you’re able to share the add-in’s source code it could help the team here narrow down the issue. Feel free to PM me (after you finish the generation effort - I’m heading home now anyway).
