Dynamo 1.3.1 and Revit 2017 Crashing When Using a Code Block
Hi All,
I just installed the update for Revit 2018 (2018.1) which Installs Dynamo 1.3.1.1736 (I think).
If I use Dynamo & Revit 2017 (btw Dynamo 1.3.0 is not available anymore), anything I write inside a code block, crashes Dynamo.:roll_eyes:
Any fixes for that?
Not seeing, this myself in Revit 2017.2 with the update. Possibly related to this post?
Thanks John.
I tried both solutions with no luck(removing AvalonEdit.dll coping DynamoSettings.xml).
This is the error:
`Method not found: 'Void ICSharpCode.AvalonEdit.Editing.TextArea.ClearSelection()'.`
       at Dynamo.UI.Controls.CodeCompletionEditor.OnTextAreaLostFocus(Object sender, RoutedEventArgs e)
       at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
       at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
       at System.Windows.UIElement.IsFocused_Changed(DependencyObject d, DependencyPropertyChangedEventArgs e)
       at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
       at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
       at ICSharpCode.AvalonEdit.Editing.TextArea.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
       at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
       at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
       at System.Windows.DependencyObject.ClearValueCommon(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata)
       at System.Windows.DependencyObject.ClearValue(DependencyPropertyKey key)
       at System.Windows.Input.FocusManager.OnFocusedElementChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
       at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
       at System.Windows.Input.FocusManager.SetFocusedElement(DependencyObject element, IInputElement value)
       at System.Windows.Input.KeyboardNavigation.UpdateFocusedElement(DependencyObject focusTarget)
       at System.Windows.FrameworkElement.OnGotKeyboardFocus(Object sender, KeyboardFocusChangedEventArgs e)
       at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
       at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
       at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
       at System.Windows.Input.InputManager.ProcessStagingArea()
       at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
       at System.Windows.Input.KeyboardDevice.ChangeFocus(DependencyObject focus, Int32 timestamp)
       at System.Windows.Input.KeyboardDevice.TryChangeFocus(DependencyObject newFocus, IKeyboardInputProvider keyboardInputProvider, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
       at System.Windows.Input.KeyboardDevice.Focus(DependencyObject focus, Boolean askOld, Boolean askNew, Boolean forceToNullIfFailed)
       at System.Windows.Input.KeyboardDevice.Focus(IInputElement element)
       at System.Windows.UIElement.Focus()
       at Dynamo.Controls.DynamoView.OnRequestReturnFocusToView()
       at Dynamo.ViewModels.DynamoViewModel.OnRequestReturnFocusToView()
       at Dynamo.ViewModels.DynamoViewModel.ExecuteCommand(RecordableCommand command)
       at Dynamo.ViewModels.WorkspaceViewModel.StateMachine.InitiateWindowSelectionSequence()
       at Dynamo.ViewModels.WorkspaceViewModel.StateMachine.HandleLeftButtonDown(Object sender, MouseButtonEventArgs e)
       at Dynamo.Views.WorkspaceView.OnMouseLeftButtonDown(Object sender, MouseButtonEventArgs e)
       at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
       at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
       at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
       at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
       at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
       at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
       at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
       at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
@salvatoredragotta do you have any other revit addins installed?
If you look at dynamo notifications (an exclamation point in the upper right of the dynamo menu) do you see any messages there?
The wrong Avalon edit .dll is being loaded when Revit starts, apparently an older or newer version which no longer has this method Dynamo relies on.
also @Zach_Kron do you have any info on the DynamoBuilds page regarding 1.3.1 installer not being there.
Yes I do. Do you need a list?
yes I have 6 System.IO.FileLoadException (attached)
System.IO.FileLoadException.pdf (33.6 KB)
@Michael_Kirschner2 Also a python script node crashes dynamo
Object reference not set to an instance of an object.
   at System.Windows.Baml2006.Baml2006Reader.Process_PropertyWithConverter()
   at System.Windows.Baml2006.Baml2006Reader.Process_OneBamlRecord()
   at System.Windows.Baml2006.Baml2006Reader.Process_BamlRecords()
   at System.Windows.Baml2006.Baml2006Reader.Read()
   at System.Windows.Markup.WpfXamlLoader.TransformNodes(XamlReader xamlReader, XamlObjectWriter xamlWriter, Boolean onlyLoadOneNode, Boolean skipJournaledProperties, Boolean shouldPassLineNumberInfo, IXamlLineInfo xamlLineInfo, IXamlLineInfoConsumer xamlLineInfoConsumer, XamlContextStack`1 stack, IStyleConnector styleConnector)
   at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
   at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
   at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
   at PythonNodeModelsWpf.ScriptEditorWindow..ctor(DynamoViewModel dynamoViewModel)
   at PythonNodeModelsWpf.PythonNodeViewCustomization.EditScriptContent()
   at PythonNodeModelsWpf.PythonNodeViewCustomization.view_MouseDown(Object sender, MouseButtonEventArgs e)
Also I uninstalled Dynamo Revit 1.3.1 but I can’t uninstall none of the following!
Dynamo 1.3.1 Release installer is now available on http://dynamobuilds.com/. If any of the problem still exist, please try running the installer again.
I have the same problem
Is il solved for you?
I found out that this bug is fixed when I uninstall Pyrevit…
