Dynamo 1.2.1 Revit installed, but no Add-In
I have recently installed Dynamo 1.2.1 for Revit on a Windows 10 computer which also has Revit 2017 installed. The installation appears to run successfully. Both the CORE and REVIT software appear in the Windows application list. However Dynamo does not appear in the Add-In ribbon menu. Anyone have thoughts about this?
Hi @brian.k.smith ,
In revit 2017 Dynamo is the manage ribbon , where it belongs :slight_smile:
@Mostafa_El_Ayoubi: Thank you for your help. This has resolved the problem.
I have uninstalled the version that comes with Revit 2017 to install the updated version 1.2.1 but it does not compare anymore on the Revit manage toolbar. What to do ?
Gerry:
I suspect that Dynamo is bundled with Revit 2017. I suggest that you repair the Revit 2017 installation by using Windows’ “Programs and Features”. Select Autodesk Revit 2017 and then Repair or Reinstall.
HTH,
-Brian
