I have installed Dynamaps from Package Manager.
It shows , it is installed in Library (screesnshot attached)
but When I click View I cannot see “Dynamaps”.
Please help on this.
Looks like you may need an update to Dynamo - what build are you using?
Jacob’s answer is right. At a minimum, you need to be on dynamo 2.0.0 for view extensions to load from the package manager and you are on a pre 2.x.x version
Thanks @jacob.small and @john_pierson… Thanks for your reply on this.
Regarding the Dynamo version , it is 1.3.4.6666.
Let me install Dyanmo 2.0.0 and give you guys a quick reply and mark the solution.
@jacob.small & @john_pierson… You both gave me the solution correctly. Dynamo forum- It allows me to pick only one person reply as a solution.
Thanks a lot guys
