DynaMaps does not work
Hello everyone
I have this error message by launching DynaMaps, someone can help me
Thank you
Capture
I guess this problem with your pc’s ip address. Try it in automatic mode.
I confess that I did not understand
can you be more precise
thx
Go to network settings. and Set IP settings Automatic.
I hope it will work. Im not sure about it.
ip
Try this, and restart. might work
Thanks anyway
it did not work.I think it’s a proxy problem, but I do not know how to solve :frowning:
@Akli.baliche
you are probably working within an organisation that forces web traffic through a proxy server- for filtering or monitoring content
It depends on how your network is set-up- you might need help from whoever looks after your network.
However- in my experience if you are at a university, government or large corporate- then it is virtually impossible to change or avoid. In this case, it will be easier to workaround the problem by using a hotspot on your phone temporarily when you need to use applications like this
HELLO
actually, it’s a business proxy problem
I get closer to network service
thank you
