Dynamaps API23?
Hello all,
does anyone know why dynamaps is not working with the RevitAPI from 23?
greetings
Kev
I believe the package needs an update; make sure you’re on the latest build and see if that fixes things. If not you can look into consuming GIS data via other methods, such as the Elk packge.
okay thanks for the quick response. I will check the alternatives.
it depends on your end use, but you can use Autodesk Forma directly instead
