Chr
July 31, 2024, 10:00am
1
Hello everyone,
I have a list from the RayBounce.ByOriginDirection node. This list shows me a start point of an element and an end point of the first element hit.
I want to calculate the length of the vector between the two points.
How can I create a new point based on the start point if the ray does not hit an element? (I hope it is explained clearly)
I tried to use List.Count to determine which dictionary only has one point, but unfortunately I don’t know how to duplicate the point from it to modify the Z value of the new point.
Thank you all!
Hi @Chr not sure why not use geometry distance to instead first create a vector and then measure the vector
Chr
July 31, 2024, 10:27am
3
Hello @sovitek , thank you for answering! I am trying to optimize this process:
Hello folks,
I have read previous posts about the same subject. I though I found a nice solution. The previous old post about the same subject here
I am working with Revit 2019 and Dynamo 2.02 6833.
I used the Revit file (Autodesk Rac advanced sample) to set the dynamo definitions.
While 1floor rooms and 3floor get their height nicely corrected,
the second floor rooms are all skipped ! I do not know why this happens.
[RoomandCeilingMatching2ndfloorproblem]
There is a list of nulls comes …
and would like to filter out / recreate rays without an endpoint.
arhh i see …probably something here for filter out rays there dont hit…can probably help
Chr
July 31, 2024, 10:42am
5
Aaah, I even saved this topic in my browser, but forgot that I had already read it. Thank you so much for the reminder, I will try it
Chr
August 1, 2024, 12:04pm
6
I would like to show my own solution in case someone wants to do something similar. Optimization suggestions are always welcome
Just to help out a little more, you can avoid warnings by transposing and using a conditional. This also allows you to run everything through the same branch.
Chr
August 8, 2024, 5:18am
8
Good Morning Nick, thank you very much for your help… It works great! I realize that I need to learn more about code blocks.
Using code blocks to layer functions is a good way to avoid warnings in many cases. Definitely worth exploring.
