Hello, I need to duplicate or copy my surface, because i have to create a lot of surfaces, but when i change the name of the original surface, the dynamo doesnt work because other surfaces depend than this, is there a node what i can use to fix this?
Have you tried copying it first using the copy node? C3D automatically renames it and then you can rename yourself an then raise
Hello Janderi,
Looks like you are renaming and raising/lowering the same surface entity (1er capa), but you are not generating any new surfaces. Check on the Tinsurface creation nodes to create new surfaces from the first one (maybe get the cogo points).
By the way, in case you are using this to display elevations on different road layer (eg) you might be interested in generating cogo point expression and work with only one surface but getting different elevations (Zoffset) on the same spot.
