Hi All,
Do we have a node that lists all the parameters in the model as a drop downlist ?
Hi All,
There are a few options for drop down lists, #springnodes and #data-shapes package’s will handle the UI side of this task. Listing all parameters might be a little more involved as a process. Can you elaborate on the parameters you are wanting and what the end result of your script is? For context, as this can help others help you.
Have a look at the node List.Dropdown in the #springnodes package, this allows for some simple inputs to define the list to select from.
Hint: You can use a code block or the Passthrough node from #clockwork to force run order for multiple drop down or pick from list selections when using this style of input in the Dynamo player environment
have a search on the forum for topics on this to expand your knowledge
I prefer the UI++ nodes from the Datashapes package for this type of ‘user selects option’ type of stuff.
