Draw Solid in dynamo
Hello, I need to draw a pipe in dynamo, I have the axis lines of the entire network.
How can I do this by drawing the geometry of a solid?
I’ve tried solid.BySweep, but to no avail
Does anyone have any tips on how to do this?
I’d use Solid.BySweep, or a Cylinder node if everything is a line.
If I use solid.bySweep how would I make the circular profile of the tube always perpendicular to the longitudinal axis?
Curve.CoordinateSystemAtParameter > Geometry.Transform
There is a specific package that I use for this. It is called Curve Pipe:
I need to draw solid pipes like this, with thickness, diameter
Ok - so two circles, one cut from the other after making the sweeps.
Hi @mateusc94 here is some ways there probably could work…
I’ll try it that way. And if I happen to have sections with different diameters, how do I draw them?
Use a different radius for your circle.
Until you try something it’s not going to make sense, so give it a shot and see what happens.
