Of course it’s possible! It was a nice and fun question, at least I enjoyed it.
If we come to the answer,
The packages you need first:
Orchid
Rhytm
First you want to specify the file name (I did it according to the Plan names here) and you need to specify which of all the files to create using "Template ". Then I wanted to make sure that the appearance of each of the related appearances was only in the file and I erased all the remaining appearances. In this way, I made the file more useful. (Not necessarily! Just my Fantasy)
Thank You for quick respond. That would be ideal case to create some add-in. Definitely what i want to have. Have to see if i could make something out of it.
Thank You for quick solution and it seems to be workable and might help tremendously now. So i tried to see if i could use for my case and came up with few errors. And can not figure out what its.
First thing is that could not find Delete Elements in Documents node so i used Springs.Doc.DeleteElements . Im assuming this might be the case.
Yet eventual it does export all files but its all empty. No details. It just copy of “Template.rte”
The interesting thing is, I got the file working great. Unfortunately, I don’t have access to the file right now, but I’m going to get back to you at the first opportunity.
This is my fault. Because I copied and pasted the existing elements in the template that I created, but that’s not what you wanted. Import a non-template element into a newly created file. That’s what I jumped. I’ve made a new correction for you. Please try this.
Thank You for giving another try im appreciated it very much.
Still having some issues that can not yet figure out how to resole it. Somehow its not exporting all details and gives - null
Some good news . Switched from Revit18 to Revit19 and problems with dynamo packages resolved. No more errors.
Now its exporting all detail views - copying Template (Template19.rte) but leaving files empty. Does not copy detail/elements itself. Copy Elements Failed
Another thing im trying to achieve is the naming convention by removing “DraftingView(Name = )”
and exporting only Detail Name.
For example : DraftingView(Name = S 03 31 30.S03 CORNER REINFORCEMENT ) in to S 03 31 30.S03 CORNER REINFORCEMENT
