Can someone explain to me why it is necessary to follow the statement
with
Seems to me like a double import statement isn’t it?
Doesnt import Autodesk
import everything inside Autodesk?
with
This would be redundant in a sense. Doing import Autodesk
would allow you to use all of the API, but you would have to type Autodesk.Revit.DB preceding every function call. Doing from Autodesk.Revit.DB import *
allows you to access the entire API directly.
With import Autodesk
new_id = Autodesk.Revit.DB.ElementId(1234567)
With from Autodesk.Revit.DB import *
new_id = ElementId(1234567)
If you are only importing from Autodesk.Revit.DB, this is generally acceptable to do since it is clear which methods/properties/etc. are from the Revit API, but can become problematic if you start importing from other modules e.g. DesignScript.
