I am trying to divide the surface for getting location for fixture placement i am facing issuse. Kindly suggest me to fix it.
The surface has to come from an element. And I think you need to be in a massing context.
i am looking for divide the surface by 10 or 20 pieces as per the requirement fixture requirements.
Thanks Jacob this one is worked to get the dividedsurface. but i cant get the surfaces divided.
May i know What is the packages of the node of (Polycurve.ClosedLoopsFromCurves)
Yes sure its from Ampersand and the splittool as well…gues it will run faster with the splittool in that case here
Dear Sovitek,
Thanks for your guide i have found the way to solve this problem.
Kindly let me know if you have any MEP design Packages Used to design the MEPF Systems in revit.
I would look into Mepover and OpenMep and Genius Loci, there are actuelly great nodes for mep in there as well ;)…these package is the most popular for MEP, and with them you can actuelly automate almost all ![]()
Thanks Sovitek
and use the forum here, many great tips and tricks
Surface.PointAtParameter might be a more efficient way to get the end results, assuming you’re not in the massing environment.
