Walls in revit from surface in dynamo
Hi everyone:
So Im trying to do the following:
1.-Get walls created with mass from revit. Check
2.-Get elements to cut / Split geometry. Check
3.-Split geometry
so i have the surface and i want to create a new wall based on this new mass.
The thing here is that i want to used revit geometry, if I import geometry as most people know i wont be able to change or manipulate the information later.
Im trying to create a wall from revit, based on a surface from dynamo. Any ideas
Sharing script and rvt
Cutting walls.dyn (65.6 KB)
Walls Geometry.rvt (2.9 MB)
