Hello all,
I’d like to know if it’s possible to divide multiple layer walls into separate (single layered) wall instances with Dynamo? I’ve already found the topic about how to decompose walls into parts (http://dynamobim.org/forums/topic/decompose-walls-using-dynamo/#post-39468) and that’s not what I need - I need the layers to be decomposed into different elements (instances), and the only way I can think of to do so is to remodel the walls (delete the multiple wall and model new single-layered walls, layer by layer)…
This is my first topic, I’m very new to Dynamo, hope you can help! Thanks
