Distributing dynamo player scripts to a large organization
I’d recommend searching the forum, there are a lot of discussions about this subject.
@Alien’s suggestion is a good one, but maybe doesn’t address the core question about a “way to convert these scripts into a format that Dynamo Player can run in its default configuration”.
To me, the short answer is: Replace all Custom Nodes with Python.
I recall a long back and forth (I thought recently) about this where @jacob.small came out very against this idea, as it puts the onus on you as the developer to update whenever the Revit API or Dynamo changes, whereas if you use packages the maintainer of the package (in theory) takes some of that burden off you. I can’t seem to find that discussion, but he makes his point here:
@steven.jensen has a super detailed post about his method here:
Also this:
and this:
and this:
and this:
