Distance beetween two objects
morning to all,
i would like to start a new script but before do that i would like to be sure that it will be possible acheive.
here i’m not asking you guys to wright the script for me, but only to tell me if it would be possible whit the OOTB nodes of dynamo to build a script capable of telling me in eatch room the major distance between the windows contained in the rooms and the walls facing them.
i attach a draw for be more e explicit.
IF IT’S POSSIBLE I WOULD LIKE JUST TO KNOT THE NAME OF ONE OR TWO NODES TO USE
thanks
Yup, definitely possible. Some nodes you might explore:
Good luck, come back here if you have further questions once you have tried to create the script
100% possible, not complicated.
Use raybounce :slight_smile:
Hi, I got fooled once with an opening
I built a script with
since then I’ve been paying attention
But it’s true that it’s powerful
Sincerely
christian.stan
From what I remember of that node you have to make sure you’ve not cropped the view…
If you have and the wall isn’t visible it’ll ignore it.
