I am searching for a method which shows a list of all used Categories in my 3D model. The categories which it should display are all the categories which are availble in the “Categories” node
Is there a way to do this? and if so how can this be done?
Thanks in advance!
@remco.de.jong181203 ,
i would prepare a view with all elements active in view…
If you just want all categories aviable in document you only need the first node.
if you want all categories used. see the picture
OBS the setup in the picture only shows Model categories that is to say 3d objects for 2d objects use the annotation output for analytics use the analytics output for views, Model Groups,Assemblies and schedules use internal.
Package Used SEGOKS and Iron Python 2.7 if you are using Revit 2023 and newer
