Hello all,
I try to make a script that let me to disassemble assembly based on it’s naming category. The script work well with the exception of the fact that it does not display proper name according to naming category as you can see below. It’s something that i miss?
Hi @nedelea.rares try something here could probably work…
Thank for your response sovitek.
Your script works to me up to the point it needs to disassemble the selected assemblies, the Assembly.Disassemble nod output null. It is nice that i can see assemblies by their name but i looking more to be able to disassemble all wall assemblies at once and let the rest intact, that’s way i use naming category parameter to filter after. Could a.name replace with something that do what i say previously?
OK try show an image with your graph with all nodes expanded
not sure is that the categori of your assembly members ? but i guess it will be an issue becourse then you can have duplicate same names ?? and what in that case an assembly have many categories member…
PS now it seems you use listview and not treeview…probably it could work with listview
what you see in the image in my previously post is the Naming Category found on assembly properties. This will allow me to select all assemblies of a type (walls, structural column, structural framing etc.) to disassemble all at once. what you see in my previously post is done using Listview Data node with showid set on false witch make the script fail because there are more than one element with same name.
yeps thats what i mean
So you say that will not be possible?
Thank very much sovitek
Your solution work well, only drawback is that i have to select manually all assembly from one category
Yes, something like this. But this way the script will only disassemble only one assemble. Maby every category to be a separate list that contain elements separate? Something like in my first post but with a name that will alow me to distinguish them.
That’s what I’m looking for. Mine keep displaying what All Elements of Category nod output only grouped by Naming Category parameter.
