DirectShape Question
Rafael,
If I can jump back in for one more comment, before we get too far with wishing that Revit was able to do things, i would only add that Revit’s geometry library is extremely limited. One does not “simply” model anything in Revit. Modeling anything more complicated than a box in Revit is like reaching the peak of Kilimanjaro. It takes a bit of work. Revit’s API is not an exception to this rule. In this case they are using the Tessellated Shape Builder because that’s the easiest hack to get an arbitrary set of geometries into Revit. Dimitar has made a tool that allows you to import gemetry in using exploded SAT imports. That kind of works but again is very limited as to what kind of geometry can actually be serialized into a SAT format. So again, it’s a little better but not exactly what we want. Huge props to Dimitar but even he cannot do what is simply not doable in revit. :frowning:
