DimensionByElement sloped pipes
Hi
I am trying to use the node Dimension.ByElements for one grid element and one pipe element. It is working fine for pipes without slopes.
However, a pipe that first has a slope and then goes straight up wont work.
I am only interested to dimension the pipe that goes straight up.
This is the error
If I press Remove Reference it seems like Dynamo has created a dimension but I can not find it.
Appreciate any help!
We had the same issue with slanted columns, revit can`t catch no ortogonal references.
Finaly we created a detail component which got placed by dynamo, than it is possible.
KR
Andreas
2020-10-15_14h36_21
Thanks, that is a possible workaround I will explore!
